Was du brauchst
Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
Remove 3 silver 4 cm Phillips screws holding down black plastic speaker cover.
Gently pull up on plastic to uncover clip connected to the camera.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
