Was du brauchst
Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
Cut 4 wire flex cable connecting the motherboard to the volume controls.
Remove volume control buttons.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
