Zum Hauptinhalt wechseln
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
Was du brauchst
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: Schritt 2, Bild 1 von 1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-4, Miles Fall 2015 Mitglied von UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 402
