Einleitung
If the front-facing or rear-facing camera on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
Was du brauchst
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
