Zum Hauptinhalt wechseln
Trio Stealth-Mini Screen Replacement
Was du brauchst
  1. Trio Stealth-Mini Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Trio Stealth-Mini Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the indentation at the bottom of the device.
  2. Trio Stealth-Mini Screen Replacement: Schritt 2, Bild 1 von 3 Trio Stealth-Mini Screen Replacement: Schritt 2, Bild 2 von 3 Trio Stealth-Mini Screen Replacement: Schritt 2, Bild 3 von 3
    • Pull on the indentation and take off the casing of the device.
  3. Trio Stealth-Mini Screen Replacement: Schritt 3, Bild 1 von 2 Trio Stealth-Mini Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the faulty battery and insert a replacement in its slot.
  4. Trio Stealth-Mini Screen Replacement, Screen: Schritt 4, Bild 1 von 1
    • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  5. Trio Stealth-Mini Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove inner casing exposing the motherboard.
  6. Trio Stealth-Mini Screen Replacement: Schritt 6, Bild 1 von 2 Trio Stealth-Mini Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove speakers by peeling back yelllow tape.
  7. Trio Stealth-Mini Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove ribbon cable on top of motherboard.
  8. Trio Stealth-Mini Screen Replacement: Schritt 8, Bild 1 von 1
    • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  9. Trio Stealth-Mini Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  10. Trio Stealth-Mini Screen Replacement: Schritt 10, Bild 1 von 1
    • Verify that all screws are detached from screen.
  11. Trio Stealth-Mini Screen Replacement: Schritt 11, Bild 1 von 1
    • Detach screen from main assembly.
Abschluss
Stewart Jenkins
207 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G1, Harley Spring 2018 Mitglied von IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
How can I do step 5? Do i need to push on the rectangle slots? It’s not very descriptive.
Nick “Blue” Wong - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 228
