Zum Hauptinhalt wechseln
Tristar Handmixer Gears Replacement
Was du brauchst
  1. Tristar Handmixer Gears Replacement, Gears: Schritt 1, Bild 1 von 3 Tristar Handmixer Gears Replacement, Gears: Schritt 1, Bild 2 von 3 Tristar Handmixer Gears Replacement, Gears: Schritt 1, Bild 3 von 3
    • Remove all the screws with the spanner and Phillips screwdrivers.
  2. Tristar Handmixer Gears Replacement: Schritt 2, Bild 1 von 3 Tristar Handmixer Gears Replacement: Schritt 2, Bild 2 von 3 Tristar Handmixer Gears Replacement: Schritt 2, Bild 3 von 3
    • Take off the mixer heads.
    • Push the eject button to do so.
    • Put the mixer in mode 5.
    • Gently open the mixer.
    • The spring might jump loose!!
  3. Tristar Handmixer Gears Replacement: Schritt 3, Bild 1 von 3 Tristar Handmixer Gears Replacement: Schritt 3, Bild 2 von 3 Tristar Handmixer Gears Replacement: Schritt 3, Bild 3 von 3
    • Remove the eject button by carefully lifting it out.
    • Remove the cable holder using the Phillips screw driver.
    • Remove the screw holding the mode button.
    • Carefully lift out the electrical unit.
  4. Tristar Handmixer Gears Replacement: Schritt 4, Bild 1 von 2 Tristar Handmixer Gears Replacement: Schritt 4, Bild 2 von 2
    • Remove the locking rings from the back end of the gears.
    • Use 2 screwdrivers to apply force on both sides of the locking rings.
    • Lift the gears from encapsulant.
  5. Tristar Handmixer Gears Replacement: Schritt 5, Bild 1 von 1
    • Replace gears.
    • Reassemble the mixer.
    • Happy mixing!
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
where can I get replacement gears from?
lanz - Antwort
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 33
Insgesamt: 1,528
