Einleitung
How to replace the TRITTON Kunai's left speaker.
Was du brauchst
Firmly grasp the black ear cushion with one hand and the white speaker frame with the other hand.
Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
Remove the two 9 mm screws indicated in red with a PH00 screwdriver.
Remove the two 7 mm screws indicated in orange with a PH00 screwdriver.
Separate the black horseshoe shaped frame from the right speaker frame.
Remove the two 7 mm screws indicated in red using a PH00 screwdriver.
Separate the black bracket and then the rail adjustment from the right speaker frame.
Remove the six 7 mm screws indicated in red using a PH00 screwdriver.
Separate the black speaker console from the right speaker frame.
Insert your new speaker into the circular shaped slot located on the speaker cover.
Solder the wires you disconnected from the old speaker to the new speaker. The red wire is to be soldered to the far left terminal, while the white wire is to be soldered to the far right terminal.
To reassemble your device, follow steps 1 through 4 in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
