Zum Hauptinhalt wechseln
Trust GXT 545 Wireless PC-PS3 Controller Disassembly
Was du brauchst
  1. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the back of the controller: Schritt 1, Bild 1 von 2 Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the back of the controller: Schritt 1, Bild 2 von 2
    • Flip over the controller.
    • Then, unscrew the 7 screws holding it together.
    • There are no screws hiding under the sticker, so there is no need to rip it off or punch a hole in it (like i tried to do in a previous attempt)
    • After removing the screws, just pull the back off of the controller. There aren't any cables attached to it.
    Frag FixBot
    Kommentar hinzufügen
  2. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the main board and vibration motors.: Schritt 2, Bild 1 von 2 Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the main board and vibration motors.: Schritt 2, Bild 2 von 2
    • First, unplug the battery connector
    • Then, undo the 8 clips that hold the board to the front casing with the flathead driver.
    • For the lower clips, you might need a slightly bigger flathead.
    • After that, just lift the board up.
    • Be careful not to break the wires that go to the vibration motors, as they are soldered to the board.
    • To remove the vibration motors, just pull them out, being careful not to break the wires.
    Frag FixBot
  3. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the buttons (only for complete disassembly): Schritt 3, Bild 1 von 1
    • Remove the screws holding the D-pad and buttons to the front case, carefully prying them out with your flathead. To remove the shoulder buttons, just pull them out.
    • Unfortunately, the clear lenses through which the status LEDs shine are glued onto the case and are not removable.
    Frag FixBot
  4. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, You are done!: Schritt 4, Bild 1 von 1
    • You now have a fully disassembled controller, ready to be repaired or modified
    Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Hello, I got this one (wired version) and I want to change joysticks as they are pretty much trash for analog control (joystick sensitivity). I want to use potenciometer ones as they are mostly used in premium brands such as microsoft and sony. What can I use? are there any things to be aware of? Any compatibility issues? I know how to disassemble it and solder it on. I just need to know which to get. I found ones from local shop called "Potenciometr Joystick PS4 JDM-055". ******Thanks for any response and have a great day :)
Creepy SK - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 87
Insgesamt: 7,166
