Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to replace the keys on the Tt Esports Poseidon Z RGB keyboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the keyboard over.
    • Flip the keyboard over.
  2. Remove the three JIS #1 screws from the back cover. Remove the three JIS #1 screws from the back cover.
    • Remove the three JIS #1 screws from the back cover.
  3. Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case. Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
    • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  4. Pull apart the two parts of the panel to expose the motherboard and keys.
    • Pull apart the two parts of the panel to expose the motherboard and keys.
  5. Use a plastic opening tool to pry off every key. Use a plastic opening tool to pry off every key.
    • Use a plastic opening tool to pry off every key.
  6. The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove. Pull these keys to the side and up. Pull these keys to the side and up.
    • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
    • Pull these keys to the side and up.
Abschluss
Marta Darmanyan
401 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 317
