Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This is a step by step guide to completely disassemble a Palm Tungsten E.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the stylus and SD card. Using a T5 torx screwdriver, remove all 4 back panel screws.
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Insert a plastic opening tool under the USB and power input slots. Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely. Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Your device may not have a screen protector. If not, you can move on to step four. Remove the screen protector by lifting the hinge out of the plastic housing.
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  5. Carefully remove motherboard from the standoffs without damaging the LCD flex connector. Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  6. Remove buttons using fingers. Gently flex frame to release screen from plastic frame. Lift out screen.
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  7. Congratulations! You have successfully taken apart a Palm Tungsten E.
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
Abschluss
Kevin Hom
88 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 13-22, Maness Winter 2010 Mitglied von Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Mitglieder
4 Anleitungen geschrieben
How does one unplug the battery?
dlcatftwin - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 10
Letzten 30 Tage: 22
Insgesamt: 6,882
