Zum Hauptinhalt wechseln
Tungsten E Power Button Repair
Was du brauchst
    1. Tungsten E Power Button Repair, Tungsten E Disassembly: Schritt 1, Bild 1 von 2 Tungsten E Power Button Repair, Tungsten E Disassembly: Schritt 1, Bild 2 von 2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      Frag FixBot
      Kommentar hinzufügen
    2. Tungsten E Power Button Repair: Schritt 2, Bild 1 von 3 Tungsten E Power Button Repair: Schritt 2, Bild 2 von 3 Tungsten E Power Button Repair: Schritt 2, Bild 3 von 3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      Frag FixBot
    3. Tungsten E Power Button Repair: Schritt 3, Bild 1 von 2 Tungsten E Power Button Repair: Schritt 3, Bild 2 von 2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      Frag FixBot
    4. Tungsten E Power Button Repair: Schritt 4, Bild 1 von 2 Tungsten E Power Button Repair: Schritt 4, Bild 2 von 2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      Frag FixBot
    5. Tungsten E Power Button Repair: Schritt 5, Bild 1 von 3 Tungsten E Power Button Repair: Schritt 5, Bild 2 von 3 Tungsten E Power Button Repair: Schritt 5, Bild 3 von 3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      Frag FixBot
    6. Tungsten E Power Button Repair: Schritt 6, Bild 1 von 1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      Frag FixBot
    1. Tungsten E Power Button Repair, Tungsten E Power Button Repair: Schritt 7, Bild 1 von 1
      Frag FixBot
    2. Tungsten E Power Button Repair: Schritt 8, Bild 1 von 1
      • On the motherboard, find the power button near the upper right corner.
      • Check for disconnection of the power button.
      Frag FixBot
    3. Tungsten E Power Button Repair: Schritt 9, Bild 1 von 1
      • Use soldering iron to reattach the damaged power button to the motherboard.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 13-22, Maness Winter 2010 Mitglied von Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 33
Insgesamt: 5,621
