Was du brauchst
Slide a spudger in between the metal casing. Slide it all around the casing, releasing the back from the clips holding it in.
The Lcd connector is held in with a double lock connector, simply push the locks forward, and the cable will disconnect with the help if a spudger.
Fast fertig!
Abschluss
