Zum Hauptinhalt wechseln
Turtle Beach Atlas One Audio Cable Replacement
Was du brauchst
  1. Turtle Beach Atlas One Audio Cable Replacement, Remove earpads: Schritt 1, Bild 1 von 3 Turtle Beach Atlas One Audio Cable Replacement, Remove earpads: Schritt 1, Bild 2 von 3 Turtle Beach Atlas One Audio Cable Replacement, Remove earpads: Schritt 1, Bild 3 von 3
    • Simply grab and pull off the pads of each earpiece
    • You will expose the 8 clip hinges, which are covered with foamy tape.
  2. Turtle Beach Atlas One Audio Cable Replacement, Exposing the clips: Schritt 2, Bild 1 von 2 Turtle Beach Atlas One Audio Cable Replacement, Exposing the clips: Schritt 2, Bild 2 von 2
    • Carefully peel off the stickers to get to the clips.
    • If the adhesive appears to be too strong, heat it with a hair dryer or a hot air station.
  3. Turtle Beach Atlas One Audio Cable Replacement, Opening the headset: Schritt 3, Bild 1 von 2 Turtle Beach Atlas One Audio Cable Replacement, Opening the headset: Schritt 3, Bild 2 von 2
    • Pry around the edges with a prying tool and unhook the hinges with a sturdy metal prying tool.
    • Once all the 4 hinges are unclipped open the headset.
    • Open with caution! Don't remove fully as the wires are still soldered to the board.
  4. Turtle Beach Atlas One Audio Cable Replacement, De-solder the old wiring: Schritt 4, Bild 1 von 3 Turtle Beach Atlas One Audio Cable Replacement, De-solder the old wiring: Schritt 4, Bild 2 von 3 Turtle Beach Atlas One Audio Cable Replacement, De-solder the old wiring: Schritt 4, Bild 3 von 3
    • Desolder the top 3 connections. RIN+, LIN+, SPKR_IN
    • And the MIN_IN, and mic ground.
    • I removed the left headset too, so it is easier to work with the headset.
  5. Turtle Beach Atlas One Audio Cable Replacement, Untying the stopper knot: Schritt 5, Bild 1 von 3 Turtle Beach Atlas One Audio Cable Replacement, Untying the stopper knot: Schritt 5, Bild 2 von 3 Turtle Beach Atlas One Audio Cable Replacement, Untying the stopper knot: Schritt 5, Bild 3 von 3
    • Now all the wires should be free.
    • Grab the end of the wire at the knot and pull a bit of slack through so you can untie the knot.
  6. Turtle Beach Atlas One Audio Cable Replacement, Removing the old cable: Schritt 6, Bild 1 von 2 Turtle Beach Atlas One Audio Cable Replacement, Removing the old cable: Schritt 6, Bild 2 von 2
    • Simply insert a new cable and re-solder the wires.
    • See the cleaned board for reference for re-soldering.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
honakrisi
3.355 Reputation
7 Anleitungen geschrieben
5 Kommentare
Hi. Thanks for this guide. Any idea where to obtain the correct replacement cable, and which wires correspond to which positions on the jack plug? Thanks.
Richard Carey - Antwort
I bought replacement cable on ebay. Look for 4 core cables (shielded if possible to reduce interference). Just use the continuity setting on your DMM to make sure you connect the new wire back the correct order.
On the ones I fixed the colouring was as below
RIN+ red
LIN+ green
SPKR_IN orange (ground)
MIC_IN+ white
MIC_IN- red+green striped (ground)
If you get a cable with a jack plug already mounted the correct connection from the tip of the jack plug to the cable side is as follows
LIN+
RIN+
SPKR_IN
MIC_IN+
Hope it helps!
honakrisi - Antwort
Fantastic - thanks so much for this. I will give it a try.
Perfect thanks. Worked a treat - headphones working again now. Thanks so much.
Glad to hear that! Well done!
honakrisi -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 1,486
