Einleitung
In order to complete this repair, you will need to order a replacement headband to replace the defective part.
Was du brauchst
Grab one end of the headband pad and pull up slightly, exposing where it is glued to to the backing.
Using a thin tool carefully scrape away the glue underneath the band while pulling the pad up, careful not to rip it.
Follow the directions of the replacement pad on how to attach it to the headband.
