Einleitung
When the audio adapter is not properly adjusting the volume or mute function, there may be a problem with the components that can be replaced. This guide shows you how to get to these parts.
Was du brauchst
With your fingers, pry apart the back casing of the audio adapter.
Remove the three black T4 4.9mm screws from around the outside on the back of the audio adapter.
Loosen the two silver T5 screws as much as possible.
Remove the two PH000 5.5mm screws from the smaller circuit board.
Remove the board.
3 weitere Personen haben diese Anleitung absolviert.
