Was du brauchst
Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
The recommended screwdriver bit size is a PH 000.
Using your hands and/or a prying tool, carefully pry open the adapter.
This step may require a bit of force to complete.
Be aware that the adapter is held together with clips on the inside at some locations.
Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
Once the screws are out, you can remove the circuit board from the casing.
Push the rubber piece containing the buttons out of the plastic adapter casing.
Then, replace it with a new one.
Eine weitere Person hat diese Anleitung absolviert.
