Zum Hauptinhalt wechseln
Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement
Was du brauchst
  1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: Schritt 1, Bild 1 von 2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: Schritt 1, Bild 2 von 2
    • The microphone is a separate piece. So, unplug it from the headset.
  2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: Schritt 2, Bild 1 von 2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: Schritt 2, Bild 2 von 2
    • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  3. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: Schritt 3, Bild 1 von 3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: Schritt 3, Bild 2 von 3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: Schritt 3, Bild 3 von 3
    • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
    • Then slide the windscreen off of the microphone.
Abschluss
Cal Poly, Team 17-36, Amido Winter 2015 Mitglied von Cal Poly, Team 17-36, Amido Winter 2015
CPSU-AMIDO-W15S17G36
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 2,742
