Zum Hauptinhalt wechseln
Turtle Beach Elite 800 Ear Cushion Replacement
Was du brauchst
  1. Turtle Beach Elite 800 Ear Cushion Replacement, Ear Cushion: Schritt 1, Bild 1 von 2 Turtle Beach Elite 800 Ear Cushion Replacement, Ear Cushion: Schritt 1, Bild 2 von 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
Abschluss
Johnny Lofton
861 Reputation
5 Anleitungen geschrieben
4 Kommentare
My left earcup unclipped where it rotates and doesn’t want to clip back in properly,how do I fix this?
Sleep Boutique - Antwort
Are Elite 800 ear pads going to fit Elite 800x headset? Im from UK and I cant find pads for 800x anywhere.
ghettiie - Antwort
It’s the same pair of headsets, only the dock is different, so yes it will fit. Please let me know if you find any ear pads that come with the plastic part, i could not find any :(
Dumitru Daniel -
I have tested this solution works as harm. https://youtu.be/0HVYC6ao8Qs
Kasia Bura - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 4,126
