Zum Hauptinhalt wechseln
Turtle Beach Elite Pro Right Speaker Replacement
Was du brauchst
  1. Turtle Beach Elite Pro Right Speaker Replacement, Ear Cushions: Schritt 1, Bild 1 von 1
    • Firmly pinch ear cushion between thumb and forefinger.
    • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
    • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
  2. Turtle Beach Elite Pro Right Speaker Replacement: Schritt 2, Bild 1 von 2 Turtle Beach Elite Pro Right Speaker Replacement: Schritt 2, Bild 2 von 2
    • Rotate ear cushion counter-clockwise about half an inch.
    • The ear cushion should audibly snap out of place.
    • After it has audibly snapped out of place, lift the ear cushion off of the device.
    • During reassembly, rotate the ear cushion clockwise.
  3. Turtle Beach Elite Pro Right Speaker Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Elite Pro Right Speaker Replacement: Schritt 3, Bild 2 von 2
    • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
    • Make sure that both the ear cushion and the orange plate have the same designation.
    • Once the pegs are aligned, push the new ear cushion in place.
  4. Turtle Beach Elite Pro Right Speaker Replacement, Right Speaker: Schritt 4, Bild 1 von 1
    • Remove the right ear cushion.
    • The right ear piece does not have any additional attachments.
  5. Turtle Beach Elite Pro Right Speaker Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
  6. Turtle Beach Elite Pro Right Speaker Replacement: Schritt 6, Bild 1 von 2 Turtle Beach Elite Pro Right Speaker Replacement: Schritt 6, Bild 2 von 2
    • Use the opening tool to separate the orange plate from the black base plate.
    • Focus on the wires that are connected to the speaker.
  7. Turtle Beach Elite Pro Right Speaker Replacement: Schritt 7, Bild 1 von 1
    • Cut the two wires that are attached to the speaker.
    • Cut the wires as close to the speaker as possible. These wires will be used in the next step.
  8. Turtle Beach Elite Pro Right Speaker Replacement: Schritt 8, Bild 1 von 2 Turtle Beach Elite Pro Right Speaker Replacement: Schritt 8, Bild 2 von 2
    • Replace the old speaker with the new speaker.
    • Using the soldering iron, solder the wires to the new speaker.
    • Make sure to solder the wires to their original locations on the speaker.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Alexis Uribe
510 Reputation
4 Anleitungen geschrieben
Baylor, Team S5-G1, Williams Spring 2017 Mitglied von Baylor, Team S5-G1, Williams Spring 2017
BU-WILLIAMS-S17S5G1
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 987
