Zum Hauptinhalt wechseln
Turtle Beach PX22 Microphone Replacement
Was du brauchst
  1. Turtle Beach PX22 Microphone Replacement, Microphone: Schritt 1, Bild 1 von 3 Turtle Beach PX22 Microphone Replacement, Microphone: Schritt 1, Bild 2 von 3 Turtle Beach PX22 Microphone Replacement, Microphone: Schritt 1, Bild 3 von 3
    • Use your fingers to peel off ear cushion by pinching and pulling off the leather.
    • Use the Philips #00 head screwdriver to remove three screws around the speaker (9/32 in length, 1/8 inch head)
    • The housing will comes loose. Take note of position of the wires.
  2. Turtle Beach PX22 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the 9/32 inch screw with a Philips 2 screwdriver to gain access to microphone.
    • You may need to pull the wire with the knot out of the way of the screw.
  3. Turtle Beach PX22 Microphone Replacement: Schritt 3, Bild 1 von 1
    • Apply heat to the circled wires on the circuit board with a heat gun.
    • Insert the new microphone and solder the wires into the correct positions.
    • Pull the excess microphone wire back into the speaker housing.
    • Use the Philips #2 screwdriver to replace the screw and fix the microphone.
    • Hold the microphone neck so that it does no rotate when screwing.
  4. Turtle Beach PX22 Microphone Replacement: Schritt 4, Bild 1 von 3 Turtle Beach PX22 Microphone Replacement: Schritt 4, Bild 2 von 3 Turtle Beach PX22 Microphone Replacement: Schritt 4, Bild 3 von 3
    • Position the speaker on the headset so that the screw holes line up. It should click into place.
    • Screw in the 3 screws with the 00 Philips head screwdriver.
    • Place the new cushion against speaker and wrap the leather around the plastic. Do this by working around the cushion to get all of the leather around the plastic.
    • Use the plastic opening tool to tuck excess leather inside the headset.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 3-1, Duarte Spring 2015 Mitglied von UMass Dartmouth, Team 3-1, Duarte Spring 2015
UMASSD-DUARTE-S15S3G1
4 Mitglieder
8 Anleitungen geschrieben
3 Kommentare
Where do we buy the mic?
Brit B - Antwort
could someone help me say what each and every on of those wire points on this logic board goes to? like 1,2,3,4,5 and 6, what do they go to???
alexalv55 - Antwort
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
rjbubba1960 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 6,735
