Einleitung
This guide shows how to replace an ineffective or broken speaker in a Turtle Beach PX22 headset. Soldering skills are needed for this job.
Was du brauchst
Use your fingers to peel off ear cushion by pinching and pulling off the leather.
Use a Phillips #00 head screwdriver to remove the three screws located around the speaker (9/32 in length, 1/8 inch head).
The housing will come loose. Take note of the position of the wires connected to the speaker.
6 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Does the speaker driver separate from the surrounding plastic disk, so it can be replaced with a like-sized driver, or is the driver plus mounting plate assembly sold as a replacement part?
