Einleitung
The motherboard is the heart of the controller, housing the essential circuits that power every function. If you're facing issues like frequent disconnections, unresponsive buttons, or other hardware malfunctions, replacing the motherboard could be the solution. Follow these steps to safely and effectively replace the motherboard and get your controller back in top condition. For this procedure, you'll need a Phillips #00 screwdriver.
Was du brauchst
Place the controller face down.
Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
Use both hands to lift the backplate away from the controller.
Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
Gently lift the motherboard up and out of the chassis.
