Zum Hauptinhalt wechseln
Turtle Beach Recon Cloud Back Casing Replacement
Was du brauchst
  1. Turtle Beach Recon Cloud Back Casing Replacement, Back Casing: Schritt 1, Bild 1 von 2 Turtle Beach Recon Cloud Back Casing Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
    • The 2 inner screws are hidden under the Turtle Beach sticker.
    • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Recon Cloud Back Casing Replacement: Schritt 2, Bild 1 von 2 Turtle Beach Recon Cloud Back Casing Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
    • Do the same to the other inner grip.
    • Do not take off the outer grips as they have wiring attached to them.
    Frag FixBot
  3. Turtle Beach Recon Cloud Back Casing Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Recon Cloud Back Casing Replacement: Schritt 3, Bild 2 von 2
    • Lift off the back casing.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 100
