Einleitung
This guide is for when you need to replace the bumpers on you Turtle Beach Recon Cloud controller for whatever reason. Follow this guide to replace your bumpers. The need for bumper replacement may be that the bumpers have been broken or they have gotten stuck.
Was du brauchst
Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
Do the same to the other inner grip.
Insert a spudger between the controller and the battery pack.
Use the spudger to loosen the battery from the motherboard.
Gently lift the battery pack until just out so as to not pull on the wire attached.
Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
Use a Phillips #00 screwdriver to remove the four screws securing the board.
Lift out the motherboard at an angle to detach it from the clips securing it to the case.
Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
Use tweezers or your fingers to gently pull the cable out of its socket.
Use a Phillips #00 screwdriver to remove the two screws above the D-pad.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
