Zum Hauptinhalt wechseln
Turtle Beach Recon Cloud Top Case Replacement
Was du brauchst
  1. Turtle Beach Recon Cloud Top Case Replacement, Back Casing: Schritt 1, Bild 1 von 2 Turtle Beach Recon Cloud Top Case Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
    • The 2 inner screws are hidden under the Turtle Beach sticker.
    • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Recon Cloud Top Case Replacement: Schritt 2, Bild 1 von 2 Turtle Beach Recon Cloud Top Case Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
    • Do the same to the other inner grip.
    • Do not take off the outer grips as they have wiring attached to them.
    Frag FixBot
  3. Turtle Beach Recon Cloud Top Case Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Recon Cloud Top Case Replacement: Schritt 3, Bild 2 von 2
    • Lift off the back casing.
    Frag FixBot
  4. Turtle Beach Recon Cloud Top Case Replacement, Battery: Schritt 4, Bild 1 von 3 Turtle Beach Recon Cloud Top Case Replacement, Battery: Schritt 4, Bild 2 von 3 Turtle Beach Recon Cloud Top Case Replacement, Battery: Schritt 4, Bild 3 von 3
    • Insert a spudger between the controller and the battery pack.
    • Use the spudger to loosen the battery from the motherboard.
    • Gently lift the battery pack until just out so as to not pull on the wire attached.
    Frag FixBot
  5. Turtle Beach Recon Cloud Top Case Replacement: Schritt 5, Bild 1 von 1
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Don't pull on the wires as this can potentially damage the socket and device.
    Frag FixBot
  6. Turtle Beach Recon Cloud Top Case Replacement, Top Case: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the four screws securing the board.
    Frag FixBot
  7. Turtle Beach Recon Cloud Top Case Replacement: Schritt 7, Bild 1 von 2 Turtle Beach Recon Cloud Top Case Replacement: Schritt 7, Bild 2 von 2
    • Lift out the motherboard at an angle to detach it from the clips securing it to the case.
    • Don't lift the motherboard roughly or pull on it. There is a ribbon cable attached to the motherboard and front case.
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 69
