Zum Hauptinhalt wechseln
Turtle Beach Recon Cloud Vibration Motors Replacement
Was du brauchst
  1. Turtle Beach Recon Cloud Vibration Motors Replacement, Back Casing: Schritt 1, Bild 1 von 2 Turtle Beach Recon Cloud Vibration Motors Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
    • The 2 inner screws are hidden under the Turtle Beach sticker.
    • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Recon Cloud Vibration Motors Replacement: Schritt 2, Bild 1 von 2 Turtle Beach Recon Cloud Vibration Motors Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
    • Do the same to the other inner grip.
    • Do not take off the outer grips as they have wiring attached to them.
    Frag FixBot
  3. Turtle Beach Recon Cloud Vibration Motors Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Recon Cloud Vibration Motors Replacement: Schritt 3, Bild 2 von 2
    • Lift off the back casing.
    Frag FixBot
  4. Turtle Beach Recon Cloud Vibration Motors Replacement, Vibration Motors: Schritt 4, Bild 1 von 2 Turtle Beach Recon Cloud Vibration Motors Replacement, Vibration Motors: Schritt 4, Bild 2 von 2
    • Unplug the vibration motor cable connector from the motherboard.
    • If the connector doesn't come out easily, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • Be careful as the connector may be tough to pull out. If so, wiggle it out of the socket.
    Frag FixBot
  5. Turtle Beach Recon Cloud Vibration Motors Replacement: Schritt 5, Bild 1 von 2 Turtle Beach Recon Cloud Vibration Motors Replacement: Schritt 5, Bild 2 von 2
    • Pull the vibration motor out from the outer grip.
    • The motor should easily come out.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 65
