Zum Hauptinhalt wechseln
Turtle Beach Recon Controller Face Plate Replacement
Was du brauchst
  1. Turtle Beach Recon Controller Face Plate Replacement, Back Plate: Schritt 1, Bild 1 von 3 Turtle Beach Recon Controller Face Plate Replacement, Back Plate: Schritt 1, Bild 2 von 3 Turtle Beach Recon Controller Face Plate Replacement, Back Plate: Schritt 1, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Recon Controller Face Plate Replacement: Schritt 2, Bild 1 von 3 Turtle Beach Recon Controller Face Plate Replacement: Schritt 2, Bild 2 von 3 Turtle Beach Recon Controller Face Plate Replacement: Schritt 2, Bild 3 von 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
    Frag FixBot
  3. Turtle Beach Recon Controller Face Plate Replacement, Face Plate: Schritt 3, Bild 1 von 2 Turtle Beach Recon Controller Face Plate Replacement, Face Plate: Schritt 3, Bild 2 von 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
    Frag FixBot
  4. Turtle Beach Recon Controller Face Plate Replacement: Schritt 4, Bild 1 von 2 Turtle Beach Recon Controller Face Plate Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
    Frag FixBot
  5. Turtle Beach Recon Controller Face Plate Replacement: Schritt 5, Bild 1 von 3 Turtle Beach Recon Controller Face Plate Replacement: Schritt 5, Bild 2 von 3 Turtle Beach Recon Controller Face Plate Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 6-1, Botvin Spring 2024 Mitglied von UMass Dartmouth, Team 6-1, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 29
Insgesamt: 548
