Zum Hauptinhalt wechseln
Turtle Beach Recon Controller Motherboard Replacement
Was du brauchst
  1. Turtle Beach Recon Controller Motherboard Replacement, Back Plate: Schritt 1, Bild 1 von 3 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: Schritt 1, Bild 2 von 3 Turtle Beach Recon Controller Motherboard Replacement, Back Plate: Schritt 1, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Recon Controller Motherboard Replacement: Schritt 2, Bild 1 von 3 Turtle Beach Recon Controller Motherboard Replacement: Schritt 2, Bild 2 von 3 Turtle Beach Recon Controller Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
    Frag FixBot
  3. Turtle Beach Recon Controller Motherboard Replacement, Face Plate: Schritt 3, Bild 1 von 2 Turtle Beach Recon Controller Motherboard Replacement, Face Plate: Schritt 3, Bild 2 von 2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
    Frag FixBot
  4. Turtle Beach Recon Controller Motherboard Replacement: Schritt 4, Bild 1 von 2 Turtle Beach Recon Controller Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
    Frag FixBot
  5. Turtle Beach Recon Controller Motherboard Replacement: Schritt 5, Bild 1 von 3 Turtle Beach Recon Controller Motherboard Replacement: Schritt 5, Bild 2 von 3 Turtle Beach Recon Controller Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
    Frag FixBot
  6. Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: Schritt 6, Bild 1 von 2 Turtle Beach Recon Controller Motherboard Replacement, Joystick Caps: Schritt 6, Bild 2 von 2
    • Use your fingers to lift both of the joystick caps off of the motherboard.
    • Remove the joystick caps.
    Frag FixBot
  7. Turtle Beach Recon Controller Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Nothing can be further removed from the motherboard. It can now be replaced.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 6-1, Botvin Spring 2024 Mitglied von UMass Dartmouth, Team 6-1, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G1
3 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
thanks for posting this!
Sean Malter - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 40
Insgesamt: 877
