Zum Hauptinhalt wechseln
Turtle Beach Stealth Ultra Back Buttons Replacement
Was du brauchst
  1. Turtle Beach Stealth Ultra Back Buttons Replacement, Back Plate: Schritt 1, Bild 1 von 2 Turtle Beach Stealth Ultra Back Buttons Replacement, Back Plate: Schritt 1, Bild 2 von 2
    • Use tweezers to pull out rubber pieces in front of the screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 2, Bild 1 von 2 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 2, Bild 2 von 2
    • Remove the 10 mm screws using a Phillips #00 screwdriver.
    Frag FixBot
  3. Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 3, Bild 2 von 2
    • Remove the sticker on the back of the plate.
    • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
    Frag FixBot
  4. Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 4, Bild 1 von 3 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 4, Bild 2 von 3 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 4, Bild 3 von 3
    • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
    • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
    • Be cautious not to break the LCD screen while you move the opening tool around.
    Frag FixBot
  5. Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 5, Bild 1 von 3 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 5, Bild 2 von 3 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 5, Bild 3 von 3
    • Use an opening tool to detach the front plate from the back.
    • You may need to work the opening tool all the way around the seam between the two plates.
    Frag FixBot
  6. Turtle Beach Stealth Ultra Back Buttons Replacement, Back Buttons: Schritt 6, Bild 1 von 3 Turtle Beach Stealth Ultra Back Buttons Replacement, Back Buttons: Schritt 6, Bild 2 von 3 Turtle Beach Stealth Ultra Back Buttons Replacement, Back Buttons: Schritt 6, Bild 3 von 3
    • Remove the four 10 mm screws from the back plate using a Phillips #00 screwdriver.
    Frag FixBot
  7. Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 7, Bild 1 von 2 Turtle Beach Stealth Ultra Back Buttons Replacement: Schritt 7, Bild 2 von 2
    • Pull the back buttons out from the backplate.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Utah Tech University, Team 1-7, McMurrin Fall 2025 Mitglied von Utah Tech University, Team 1-7, McMurrin Fall 2025
UTAHTECH-MCMURRIN-F25S1G7
2 Mitglieder
7 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where do you get the replacement buttons from?
Drew Steig - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 373
