Zum Hauptinhalt wechseln
Turtle Beach Stealth Ultra Back Plate Replacement
Was du brauchst
  1. Turtle Beach Stealth Ultra Back Plate Replacement, Back Plate: Schritt 1, Bild 1 von 2 Turtle Beach Stealth Ultra Back Plate Replacement, Back Plate: Schritt 1, Bild 2 von 2
    • Use tweezers to pull out rubber pieces in front of the screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 2, Bild 1 von 2 Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 2, Bild 2 von 2
    • Remove the 10 mm screws using a Phillips #00 screwdriver.
    Frag FixBot
  3. Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 3, Bild 2 von 2
    • Remove the sticker on the back of the plate.
    • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
    Frag FixBot
  4. Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 4, Bild 1 von 3 Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 4, Bild 2 von 3 Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 4, Bild 3 von 3
    • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
    • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
    • Be cautious not to break the LCD screen while you move the opening tool around.
    Frag FixBot
  5. Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 5, Bild 1 von 3 Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 5, Bild 2 von 3 Turtle Beach Stealth Ultra Back Plate Replacement: Schritt 5, Bild 3 von 3
    • Use an opening tool to detach the front plate from the back.
    • You may need to work the opening tool all the way around the seam between the two plates.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Utah Tech University, Team 1-7, McMurrin Fall 2025 Mitglied von Utah Tech University, Team 1-7, McMurrin Fall 2025
UTAHTECH-MCMURRIN-F25S1G7
2 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 59
Insgesamt: 278
