Einleitung
In order to replace anything in your Turtle Beach Stealth Ultra controller (model number TBS-0710-05), you first need to detach the backplate from the front plate. The back plate is responsible for keeping the internal parts of the controller protected. While following this guide, be cautious not to damage the LCD screen or motherboard. Follow these steps to remove the back plate.
Additional Resources:
Stealth Ultra Controller Support Site
Video on Turtle Beach Stealth Ultra Disassembly and Reassembly
Was du brauchst
Remove the sticker on the back of the plate.
Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
Use an iFixit opening tool to pry the front button plate and analog stick plate off.
Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
Eine weitere Person hat diese Anleitung absolviert.
