Einleitung
The battery in the Turtle Beach Stealth Ultra controller (model number TBS-0710-05) is responsible for holding the controller's charge and allowing users to play wirelessly. In order to replace it, you first need to disassemble the controller. As you do, be cautious not to damage the screen or motherboard. Follow these steps to fix it.
Additional Resources:
Stealth Ultra Controller Support Site
Video on Turtle Beach Stealth Ultra Disassembly and Reassembly
Was du brauchst
Remove the sticker on the back of the plate.
Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
Use an iFixit opening tool to pry the front button plate and analog stick plate off.
Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
Use a Phillips #00 screwdriver to remove the 10 mm screws connecting the handles to the controller frame.
Remove the six 10 mm screws connected to the motherboard using a Phillips #00 screwdriver.
Use the Phillips #00 screwdriver to remove the 10 mm screws from the black battery bracket.
Pull the battery bracket off of the battery.
Detach the cable connector from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
