Zum Hauptinhalt wechseln
UDI U842 Quadcopter DC Motor Replacement
Was du brauchst
  1. UDI U842 Quadcopter DC Motor Replacement, Bottom Light: Schritt 1, Bild 1 von 2 UDI U842 Quadcopter DC Motor Replacement, Bottom Light: Schritt 1, Bild 2 von 2
    • To open up the motor housing, first remove the bottom light by unscrewing,
    • One 6mm Phillips screw.
  2. UDI U842 Quadcopter DC Motor Replacement, Propeller Bumper: Schritt 2, Bild 1 von 3 UDI U842 Quadcopter DC Motor Replacement, Propeller Bumper: Schritt 2, Bild 2 von 3 UDI U842 Quadcopter DC Motor Replacement, Propeller Bumper: Schritt 2, Bild 3 von 3
    • Unscrew the single propeller bumper screw on the outside of the of the motor housing.
  3. UDI U842 Quadcopter DC Motor Replacement: Schritt 3, Bild 1 von 3 UDI U842 Quadcopter DC Motor Replacement: Schritt 3, Bild 2 von 3 UDI U842 Quadcopter DC Motor Replacement: Schritt 3, Bild 3 von 3
    • Push up on each of the two tabs that connect the bumper to the bottom casing.
    • Slide the bumper up off of the drone.
    • The propeller is not shown in these photos because the steps for removing the bumper and the propeller are interchangeable. Choose whichever sequence feels most comfortable!
  4. UDI U842 Quadcopter DC Motor Replacement: Schritt 4, Bild 1 von 2 UDI U842 Quadcopter DC Motor Replacement: Schritt 4, Bild 2 von 2
    • To remove the propeller, first unscrew the propeller set screw.
    • Next, slide the propeller up off the motor gear shaft.
  5. UDI U842 Quadcopter DC Motor Replacement, Motor Casing Screws: Schritt 5, Bild 1 von 2 UDI U842 Quadcopter DC Motor Replacement, Motor Casing Screws: Schritt 5, Bild 2 von 2
    • Unscrew the three screws on the perimeter of the motor casing.
    • Three 6mm Phillips screws.
  6. UDI U842 Quadcopter DC Motor Replacement, Motor Casing: Schritt 6, Bild 1 von 3 UDI U842 Quadcopter DC Motor Replacement, Motor Casing: Schritt 6, Bild 2 von 3 UDI U842 Quadcopter DC Motor Replacement, Motor Casing: Schritt 6, Bild 3 von 3
    • Remove the motor casing by pulling up on the edges of the prismatic housing.
    • The casing may require heavy force to remove. Be cautious to avoid breaking the mating pins (shown up close in the third picture).
  7. UDI U842 Quadcopter DC Motor Replacement, Motor Mounting Screws: Schritt 7, Bild 1 von 2 UDI U842 Quadcopter DC Motor Replacement, Motor Mounting Screws: Schritt 7, Bild 2 von 2
    • Remove the three motor mounting screws.
  8. UDI U842 Quadcopter DC Motor Replacement, Detach Motor Cable: Schritt 8, Bild 1 von 2 UDI U842 Quadcopter DC Motor Replacement, Detach Motor Cable: Schritt 8, Bild 2 von 2
    • The motor-cable plug appears to be covered in a waxy sealing material.
    • Use a thin blade or an X-ACTO knife to slice along the bottom of the wax to free the plug.
  9. UDI U842 Quadcopter DC Motor Replacement: Schritt 9, Bild 1 von 3 UDI U842 Quadcopter DC Motor Replacement: Schritt 9, Bild 2 von 3 UDI U842 Quadcopter DC Motor Replacement: Schritt 9, Bild 3 von 3
    • Detach the motor cable by pulling outward and gently wiggling the plug.
    • Be careful to avoid pulling off the board-mounted connector, as shown in the third photo. If the connector starts to come loose, just press it back down and it will snap into place.
  10. UDI U842 Quadcopter DC Motor Replacement: Schritt 10, Bild 1 von 2 UDI U842 Quadcopter DC Motor Replacement: Schritt 10, Bild 2 von 2
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Adrian Eaton
614 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 70-2, Forte Winter 2015 Mitglied von Cal Poly, Team 70-2, Forte Winter 2015
CPSU-FORTE-W15S70G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 28
Insgesamt: 976
