Zum Hauptinhalt wechseln
UE BOOM 2 Micro-USB Port Replacement
Was du brauchst
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: Schritt 1, Bild 1 von 2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: Schritt 1, Bild 2 von 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: Schritt 2, Bild 1 von 2 UE BOOM 2 Micro-USB Port Replacement: Schritt 2, Bild 2 von 2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: Schritt 3, Bild 1 von 3 UE BOOM 2 Micro-USB Port Replacement: Schritt 3, Bild 2 von 3 UE BOOM 2 Micro-USB Port Replacement: Schritt 3, Bild 3 von 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Micro-USB Port Replacement: Schritt 4, Bild 1 von 1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: Schritt 5, Bild 1 von 3 UE BOOM 2 Micro-USB Port Replacement: Schritt 5, Bild 2 von 3 UE BOOM 2 Micro-USB Port Replacement: Schritt 5, Bild 3 von 3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Bahm
2.151 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S12-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Mitglieder
15 Anleitungen geschrieben
6 Kommentare
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Antwort
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Antwort
i too am looking to find the replacement part
Liam Nicholls - Antwort
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Antwort
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 8
Letzten 7 Tage: 43
Letzten 30 Tage: 151
Insgesamt: 6,555
