Einleitung
The spool holder is a 3D printed part that holds the filament spool and the feed tube, keeping it stable and secure to the system. Be sure to print a spare spool holder prior to replacement.
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
  1. Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards. Wait for a "beeping" sound before removing filament. Cut off any damaged plastic from the end of the filament.
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the spool from the spool holder by lifting it up and taking it off. Put the end of the filament through the hole on the side of the spool to keep it from unraveling. Slide the spool holder upwards, and then pull outwards.
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  5. Place the new spool holder by pushing it inwards and sliding it down until it locks. Repeat the steps in reverse chronological order to reassemble the printer. The spool should be inserted in way that end of the filament points towards, not away.
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
Ziellinie
3 weitere Nutzer haben diese Anleitung absolviert.
valerie boyer
469 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-31, Maness Fall 2014 Mitglied von Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 643
