Zum Hauptinhalt wechseln
UTStarcom CDM8945vw Keyboard Replacement
Was du brauchst
  1. UTStarcom CDM8945vw Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery.
  3. UTStarcom CDM8945vw Keyboard Replacement, Antenna: Schritt 3, Bild 1 von 1
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Keyboard Replacement: Schritt 5, Bild 1 von 2 UTStarcom CDM8945vw Keyboard Replacement: Schritt 5, Bild 2 von 2
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Keyboard Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Keyboard Replacement: Schritt 11, Bild 1 von 2 UTStarcom CDM8945vw Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  12. UTStarcom CDM8945vw Keyboard Replacement, Logic Board: Schritt 12, Bild 1 von 1
    • Detach the highlighted piece from the logic board using a plastic opening tool.
  13. UTStarcom CDM8945vw Keyboard Replacement: Schritt 13, Bild 1 von 2 UTStarcom CDM8945vw Keyboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
  14. UTStarcom CDM8945vw Keyboard Replacement, Keyboard: Schritt 14, Bild 1 von 1
    • Remove the keyboard.
Abschluss
Bryon Hazlewood
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 24-26, Regan Fall 2012 Mitglied von Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 310
