Einleitung
A small amount of disassembly is required to replace the camera. The beginner can complete this task with just a couple tools.
Was du brauchst
Remove the battery cover by pressing and sliding the cover down and off of the phone.
Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
