Zum Hauptinhalt wechseln
UTStarcom XV6700 Camera Replacement
Was du brauchst
  1. UTStarcom XV6700 Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Camera Replacement: Schritt 3, Bild 1 von 3 UTStarcom XV6700 Camera Replacement: Schritt 3, Bild 2 von 3 UTStarcom XV6700 Camera Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
  4. UTStarcom XV6700 Camera Replacement, Camera: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
  5. UTStarcom XV6700 Camera Replacement: Schritt 5, Bild 1 von 2 UTStarcom XV6700 Camera Replacement: Schritt 5, Bild 2 von 2
    • Use firm pressure to carefully pry off the cover with your fingers.
  6. UTStarcom XV6700 Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
  7. UTStarcom XV6700 Camera Replacement: Schritt 7, Bild 1 von 1
    • Gently pry off the camera flash circuit board with the spudger.
  8. UTStarcom XV6700 Camera Replacement: Schritt 8, Bild 1 von 1
    • Gently pry off the camera with the spudger.
Abschluss
Jesse Walker
201 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 193
