Einleitung
This guide will show you how to replace the battery of your Udi U818A FPV drone controller. You will need a JIS #0 screwdriver to complete this task.
Was du brauchst
Turn the remote control over so that the buttons and joysticks are facing downward.
Using a JIS #0, unscrew the silver 4mm screw that holds the battery cover in place.
Open the battery access panel.
Disconnect the red and black wires.
Remove the depleted battery.
