Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If your Udi Discovery U818A FPV drone is sluggish or fails to respond, this guide will show you how to replace the drone battery. No tools are required for this task.
  1. Locate the drone battery housed in the slot between the drone body and the camera.
    • Locate the drone battery housed in the slot between the drone body and the camera.
  2. Disconnect the battery from the drone by separating the red and black battery cable from the red and black drone cable.
    • Disconnect the battery from the drone by separating the red and black battery cable from the red and black drone cable.
  3. Remove the battery from the slot by pulling on the silver tab attached to the exposed end of the battery.
    • Remove the battery from the slot by pulling on the silver tab attached to the exposed end of the battery.
Abschluss
Debra Crawford
401 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 188
