Einleitung
This guide explains how to replace the back camera on the Unbranded Tablet.
Was du brauchst
Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
As the gaps open, slide the guitar picks along the sides to separate the panels.
Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
