Zum Hauptinhalt wechseln
Unbranded UB-15MS10 Back Camera Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Unbranded UB-15MS10 Back Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. Unbranded UB-15MS10 Back Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. Unbranded UB-15MS10 Back Camera Replacement: Schritt 3, Bild 1 von 2 Unbranded UB-15MS10 Back Camera Replacement: Schritt 3, Bild 2 von 2
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. Unbranded UB-15MS10 Back Camera Replacement: Schritt 4, Bild 1 von 1
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. Unbranded UB-15MS10 Back Camera Replacement: Schritt 5, Bild 1 von 1
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
  6. Unbranded UB-15MS10 Back Camera Replacement, Back Camera: Schritt 6, Bild 1 von 1
    • Remove the small piece of black tape.
  7. Unbranded UB-15MS10 Back Camera Replacement: Schritt 7, Bild 1 von 1
    • Remove the black 4-mm #0 screw.
  8. Unbranded UB-15MS10 Back Camera Replacement: Schritt 8, Bild 1 von 1
    • To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
    • There are two very small prongs on the side which need to be pushed towards the center of the connector to remove it.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Jordan Turk
331 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-1, Baechle Fall 2015 Mitglied von IUPUI, Team 2-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 712
