Zum Hauptinhalt wechseln
Unbranded UB-15MS10 Battery Replacement
Was du brauchst
  1. Unbranded UB-15MS10 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
  3. Unbranded UB-15MS10 Battery Replacement: Schritt 3, Bild 1 von 2 Unbranded UB-15MS10 Battery Replacement: Schritt 3, Bild 2 von 2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Battery Replacement: Schritt 4, Bild 1 von 1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Battery Replacement: Schritt 6, Bild 1 von 1
    • Cut the wires connecting the battery to the device using a pair of wire cutters.
  7. Unbranded UB-15MS10 Battery Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the battery, making sure that all wires are disconnected.
  8. Unbranded UB-15MS10 Battery Replacement: Schritt 8, Bild 1 von 1
    • Splice the new battery with the red, white, and black wires connected to the motherboard.
Abschluss
To reassemble your device, follow directions 1-7 in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Evan Peterson
320 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G5, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G5, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G5
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 2,269
