Was du brauchst
Use an opening tool to pry off the memory card door located on the back of the tablet.
Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
Detach the three ribbon cables using a spudger
Desolder the black, white, and red wires.
Remove the old motherboard from the tablet.
Take the new motherboard and solder the black wire of the board to the black wire of the battery.
Do the same for the white and red wires.
To reassemble your device, follow steps 1-10 in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
