Zum Hauptinhalt wechseln
Uniden D1483-3BK Circuit Board/Screen Replacement
Was du brauchst
  1. Uniden D1483-3BK Circuit Board/Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 2, Bild 1 von 2 Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: Schritt 4, Bild 1 von 2 Uniden D1483-3BK Circuit Board/Screen Replacement, Handset Case: Schritt 4, Bild 2 von 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 5, Bild 1 von 3 Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 5, Bild 2 von 3 Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 6, Bild 1 von 2 Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 7, Bild 1 von 2 Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 7, Bild 2 von 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Circuit Board/Screen Replacement, Circuit Board/Screen: Schritt 8, Bild 1 von 1
    • Set the circuit board on the table with the screen facing down.
  9. Uniden D1483-3BK Circuit Board/Screen Replacement: Schritt 9, Bild 1 von 1
    • Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
    • When installing the new board, use the soldering iron and solder to reattach the speaker cables.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Arbitrary Name
1.083 Reputation
4 Anleitungen geschrieben
Penn State, Team 1-8, Kaschak Winter 2015 Mitglied von Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 308
