Einleitung
To complete this guide you will have to disassemble the handset and use a soldering iron to replace the circuit board. Other than the soldering process, the guide steps are medium in difficulty to complete. After completing this guide, users should have a fully operating, handset circuit board and screen.
Was du brauchst
Slide the battery cover toward the bottom of the phone.
Lift and remove the back cover from the phone.
Remove the battery from its compartment.
Pinch the end of cord where the battery is attached to the phone and pull up gently.
Use the plastic opening tool to carefully separate the two halves of the case.
Slowly work around the entire case to fully separate the halves before pulling them apart.
Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
Set the board in the lower half of the case.
Set the circuit board on the table with the screen facing down.
Using the desoldering braid and soldering iron, remove the solder around the cable for the speaker.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
