Was du brauchst
Use the plastic opening tool to carefully separate the two halves of the case.
Slowly work around the entire case to fully separate the halves before pulling them apart.
Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
Set the board in the lower half of the case.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
