Einleitung
Outline what you are going to teach someone how to do.
Was du brauchst
Pull the small, grey connector that is connected to the phone to disconnect the battery pack.
Remove the two 3.175 mm screws with the small Phillips head (PH1) screwdriver on the bottom of the phone next to where the battery was removed.
Once removed, use plastic opening tool to pull the back and front apart in 3 different locations; the bottom and both sides.
After splitting the phone there will be 2 wires that connect the phone's circuit board with the speaker on the back.
The circuit board (Large Green) is attached by 1 3.175mm screw in the top, left corner.
Remove this screw using a small Phillips head screwdriver (PH!) from the iFixit toolkit.
Once the screw has been removed, the circuit board will be removable.
Gently remove the circuit board and place it on the back of the phone.
The keyboard will now be accessible. Remove the Bumper Pad (rubber pad behind actual keypad).
Remove the keypad.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Did all of the above but I can’t get the center piece to work! I have no volume control and I can’t access anything like phone numbers, etc.
