Einleitung
We are going to teach you how to remove bottom shell circuit board. By removing this, you will learn how to dissemble the speaker.
Was du brauchst
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
Using the spudger, separate the top shell of the base from the bottom shell from the base.
Lift the top shell off the bottom, and you have successfully opened the phone base.
Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
Unscrew bottom shell circuit board screws(Head size: 4mm Length: 8.6mm).
