Zum Hauptinhalt wechseln
Uniden D1688 Top Circuit Board Replacement
Was du brauchst
  1. Uniden D1688 Top Circuit Board Replacement, Uniden D1688 Base Replacement: Schritt 1, Bild 1 von 1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Top Circuit Board Replacement: Schritt 2, Bild 1 von 2 Uniden D1688 Top Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
  3. Uniden D1688 Top Circuit Board Replacement, Top Circuit Board: Schritt 3, Bild 1 von 1
    • Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
  4. Uniden D1688 Top Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
  5. Uniden D1688 Top Circuit Board Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the ribbon cable from the bottom shell circuit board.
  6. Uniden D1688 Top Circuit Board Replacement: Schritt 6, Bild 1 von 1
    • Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
  7. Uniden D1688 Top Circuit Board Replacement: Schritt 7, Bild 1 von 1
    • Remove top shell circuit board by lifting the circuit board out of the case
Abschluss
justin
419 Reputation
4 Anleitungen geschrieben
Pasco Hernando, Team 1-4, Prince Winter 2015 Mitglied von Pasco Hernando, Team 1-4, Prince Winter 2015
PHSC-PRINCE-W15S1G4
6 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 170
